Nev, I think you are referring to the 4 place. The Patrol strut is formed and drilled at each end so no threads.
Mark, Mike Silvernagle mentioned making 6 strips so that's what I used pr side. He may have only added three a side. Unclear on that whether he attached the six to the one strut that was vibrating or three to each.
Mike wrote:
" I ended up cutting 6 pieces of 1/4" wide strips of velcro 1" long and sticking them to the underside of the 4130 streamlined tubing"
If the weather was warmer and I had the opportunity to play with the strips, I'd see what the minimum would be to eliminate the vibration.
Thanks for the feed back guys.
