No. 2 Swage-it tool
  • No. 2 Swage-it tool
    I bought this from ACS years ago and am just now getting around to using it. I immediately noticed the holes were slightly misaligned so that when you insert a nicopress sleeve it's not quite straight. Thus when it's clamped, the end result is a bit crooked.
    Then if I loosen the tool, rotate the sleeve a bit, and clamp it again, it comes out looking fairly normal and passes the go-no-go test.
    While I'm not particularly excited about the misalignment, is it the look and measurement of the end result that matters most or should I scrap this thing and buy a (gulp) expensive one?
    What about drilling out threads in bottom plate and open holes a little to get aligned. Then use longer bolts and nuts. You could even weld nuts on bottom of bottom block. Could also maybe drill a 1/8” hole with a alignment pin so easier to keep lined up while tightening up.
      While at times in the past I've had some ACS frustrations, in recent years there have been instances where they go well above and beyond. I'd contact them to give it a shot anyway, hopefully we'll here back a great report. I'd personally not be satisfied with the two step work around you mentioned due to work hardening and the critical nature of most of those connections.
        You might also consider contacting the manufacturer directly. I use that same tool, and mine has proper alignment. The manufacturer has huge incentive to protect there name I'm sure hey know that a production run of tools went out the door that did not meet there own standards.
        rigging equipment, wire rope, shackles, ferrules, arborist ropes, cable rails, turnbuckles
          Is that 3rd one considered finished?
          • nichzimmerman
            nichzimmerman commented
            The third one was clamped once. After the photo I rotated it in the tool and clamped it again and it looks normal now.
            Agree - that does not look anywhere near tight enough, but I am used to seeing the control cable rather than the small stuff.
          It is quite obviously a manufacturing defect. I don't think ACS or the manufacturer could dispute that. Nicopress sleeves need to be done really well to be achieve full strength.
            Update: I sent the manufacturer the pictures above and they immediately mailed a replacement tool and asked that I return the original on their dime for analysis. Great service.
            -Nic
              Good to hear they are taking care of you. I have the same tool but mine is aligned properly and works well.
              Rollie VanDorn
              Findlay, OH
              Patrol Quick Build
