I bought this from ACS years ago and am just now getting around to using it. I immediately noticed the holes were slightly misaligned so that when you insert a nicopress sleeve it's not quite straight. Thus when it's clamped, the end result is a bit crooked.
Then if I loosen the tool, rotate the sleeve a bit, and clamp it again, it comes out looking fairly normal and passes the go-no-go test.
While I'm not particularly excited about the misalignment, is it the look and measurement of the end result that matters most or should I scrap this thing and buy a (gulp) expensive one?
