Rod end bearings rivets
  • Rod end bearings rivets
    Should i have any concerns forming shop heads on the aileron and flap rod end bearings where they rivet into hinge tubes since the rod end bearings i have are hollow at the ends ? Thanks
    Normal AN470AD-5 rivets used. Mark
      Thanks mark..
      just wasn't sure if the hollow center would cause it to collapse in center before shop head was formed
        If your squeezer is square on the rivet it should not be a problem making a good shop head, also it needs to be the exact diameter rivet called out in the plans.
          Can a 3000# squeezer do a AD5 rivet? I recall mine says it's only good for AD4 and smaller.
          Dave B.
          Plane Grips Co.
          www.planegrips.com
            There is one easy way to find out... If it turns out not to, I once used a polished ball peen hammer to form the shop head on some 3/16 rivets. I drilled a 3/16 hole in the anvil of the vice, put the squeezer set in that hole, and a few wacks later all was good.
              My squeezer would not do them. I think Eric addresses this in his manual. The lock tight is what hold the ends in place anyways.
                Yeah I figured I'd just be hitting it with a hammer when the time came per Newton's manual.
                Dave B.
                Plane Grips Co.
                www.planegrips.com
                  Anyone know off hand if red loctite will do? And a couple rivets!
                    You can also use an AN3 clevis or regular bolt.
                      It's only a few dollars to invest in the right stuff, and then you know.
                        Is red locktite not the right stuff? I don’t have Eric’s manual here but I’m pretty sure we used red locktite based on info from Eric’s manual.
                          That’s the way I remember it, too.
                            Desert Bearhawk (if you’re a Facebook follower) just said the same thing. He uses red loctite, aligns everything, lets it cure to hold everything in place, then drills them. Handy tip, methinks.
                            Northwest, Wisconsin, USA
                              Just used red loctite. Sitting overnight. Thanks all
