Has anyone else had the problem of the aileron cables rubbing at the top of the strut? I am using the larger pulleys and still have the issue. To correct it I need to move the pulleys mount point about 1/2" inboard. I am going to modify the pulley brackets to accomplish that.
Cable rubbing in Strut
Rodsmith, you lost me on your statement of moving the pulley inboard, that would compound the problem if the cable is touching the top of the strut. I am a plans builder and I had this problem. I moved the pulley outboard thus keeping the alignment correct to the outboard pulley. I had to punch out a rivet and made a 4130 bridge to mount the pulley at a new location. I was able to correct my error as the clues were not correct . Stinger
It was rubbing on the bottom side of the strut. I spent a few hours modifying the brackets to move the pulley's a 1/2 " inboard. That put the cables right in the center of the strut.The aileron cross over cable was rubbing on the flap support frame tubing on both sides. I added a fairlead on the rib outboard of the flap frame on each side to fix that, still very close.Last edited by rodsmith; 08-13-2017, 10:00 AM.
FYI;
The B model uses 3" pulleys in the wing at the top of the lift strut. The cable rubs the top of the strut fairly significantly I am going to try a smaller pulley before I notch the lift strut..
I was going to order 2" ones but forgot how expensive they are. Looking around the airframe I found some 1.75" one with a AN5 bolt on the bottom of the fuselage. Tried them and they fit perfect. 2 " might still rub just slightly.
That is the good news. The bad news is my aileron cables just magically got longer.
I'm having the same issue. Is there any problem with cutting a small fillet at the rear of the top of the strut for clearance? I can't imagine that is a highly stressed area. In any case, a properly curved and finished fillet may actually reduce the stress as opposed to a square corner ......
