It seems that I read in a post the folks have had to cut the control stick a small amount to make it clear the dash. I'm trying to make that determination. I have clamped the dash panel in place and the panel sticks about an inch below the bottom tube that supports the panel. Consequently the stick contacts the panel as you move it to the forward position. ( I would really like to keep this panel length.)
Did anyone else see this problem or cut the stick?
Let me clarify that I do not have the elevator installed with the cables hooked to the controls so I really don't know what the travel of the stick will be in the forward position. Haven't put the tail feathers on since it's easier to move the plane around the shop with out them.
Do I need the tail feathers installed to make this determination?
