Those that have a QB fuselage and installed float fittings(after the fact) and preferably have run floats, what, if any, reinforcements did you make to the rest of the air frame, specifically under the rear cargo door? I've seen a couple posts of upgrading tubing diameter/thickness for a couple tubes and adding a tube. I know Maule has you weld a plate in back there. Just trying to see what, if anything, is commonly done.
On that note I'm probably going to start messing with my rigging, so curious on some dimensions.
1) distance between the floats you went with, normally it's in the 40-50% of the length of the float range, but just curious what you went with.
2)Height above the aircraft - minimum is 12" prop clearance off the water, but most are more than that. This does effect step position, so I'd like to know what you went with, why and how that's working.
3)Angle between datum and floats(this is called throat, I think) and then of course the angle of incidence you installed your wings at and the HP of your motor. Following Edo's rule of thumb, for my aircraft - angle of incidence(2) and HP(260), I come up with -3.15 degrees to datum.
4)Where did you put the step in relation to the CG datum? Why?
I'm using these two articles as guides on this - https://glasair-owners.com/glastar-s...n-maintenance/ http://www.stoneylake.org/pipcom/floatgeo.htm
