Anyone know anything about the AC Aero (Higgs Diesel) stepped piston, Spark ignition, multi-fuel engine? http://www.ac-aero.com/jet-a/
Have been watching this engine for a while, and it looks like the first run of pre-production engines should be being tested / possibly being installed in aircraft.
(http://www.vansairforce.com/communit...d.php?t=167537)
The E330 (300 hp - Naturally aspirated version) could be an interesting future option for a Bearhawk 4 place.
The E330 is 301 lbs without accessories or cooling system. One estimate I read says 350 lbs. with accessories installed... Not sure if that includes the cooling system I would assume it does not. Just looking around at IO-540 weights, (which depending on where I look are listed as 400-480 pounds with accessories) the E330 may end up being about the same or even possibly less with the cooling system included.
Anyone want to tell me hanging weight of their engine with accessories I would be interested to know. ( would be interested in numbers for both the 360's and 540's)
The really interesting part to me is the .398 BSFC, so something like 180 hp at 60% cruise burning 10.7 gph Jet A. ( If the advertised number hold true into production) Plus you get to burn Jet A so theoretically the fuel will be cheaper. Plus you get a few extra Hp on takeoff over the IO-540.
Could be a winner if it comes close to the estimated performance and weight numbers.
What are your thoughts?
Aaron
Aaron
