I was watching one of Mike Patey's recent videos and he used a combination of CF and Kevlar for skins for the tail feathers. I am not advocating that for a BH, but I did use the combination for most of the interior. Most of the panels are a 2 layers, one of CF and one of Kevlar. The Kevlar is facing the interior of the cabin. On the small panels next to the front seats I used 3 layers for stiffness and strength, but they are only a few square feet. The larger panels on the left side I put some small balsa triangles and carbon tape on the hidden side for extra stiffness. I will either use Oratex or CF/Kevlar for the ceiling. Probably Oratex as it is even lighter and probably doesn't need to be removable.
They are about 16 oz/sq yard, and the side on the inside is Kevlar in case of a crash. The Kevlar doesn't add much strength, but it will never completely fail. It might crack the carbon, but the Kevlar will hold it together and you can repair it.
They are removable and I used very light homemade (.032 or .025) straps with a nut plate to mount the Kevlar, and hold it to the fuselage tubing. I will hunt for some pics and try to post them.
