Yesterday I spent 2 hours at 8000 ft trying different fuel scenarios.
Firstly I ran the Left tank dry by running only from the left tank. It took quite some time to run the fuel level down as I was running LOP.
The engine first surged several times with approximately 5-8 liters in the tank, so I think it was unporting at this stage. I then selected the right tank, and the engine restarted within around 5 seconds with the fuel pump off.
At this stage I could still see fuel in the left sight gauge, so I repeated the same process a number of times. Each time I was surprised at how long the engine would run for before stopping again. I was also able to keep it running by putting the aircraft out of balance (and flooding the ports )such that the fuel pickups were flooded. Eventually this was no longer possible and at that point I could no longer start the engine from the the left tank. One point that was clear is that with little fuel in the tank, being out of balance away from the ports very quickly unported the tank and stopped the engine.
During this time on several occasions I selected BOTH, and observed that the engine restarted each time in around 5 seconds and ran well. Each time the engine stopped it was preceded by the fuel pressure dropping approximately 10 seconds beforehand and as a result I've now set the low fuel pressure alarm to come on at 20 psi, which just gives enough warning to change tanks. The fuel pressure could also be seen rising just before the engine restarted.
Once the left tank was completely dry, I selected BOTH again, the engine restarted, and I flew for approximately 45 minutes at a cruise power setting. Then I put the aircraft well out of balance and flew for 5 minutes before repeating the out of balance to the opposite side. The engine continued to run normally. At various times I turned the electric fuel pump on, but there was no difference.
Finally, I descended to 2000ft (still on BOTH, with the Left tank empty). I then set climb power and climbed through several thousand feet with a pitch attitude of 10-15°. The engine continued to run normally. I landed with 30 liters in the right tank, and the left tank empty. I then refuelled and noted that the left tank took 103.6 liters to fill.
This exercise has given me alot more confidence on my aircraft to run in the BOTH position, even with a large fuel imbalance. It has also made me reluctant to select an individual tank when it has a low fuel quantity. When running LOP my fuel burn is around 37-42 LPH, so 30 mins reserve is only 20 liters, or 10 aside. I'm still getting my head around this, but I would think that on my aircraft the BOTH position would be safest as Bob intended.
I'm posting this here as another data point regarding possible unporting of tanks in other threads. Bear in mind that I'm not a test pilot, and all of our aircraft have differences. Mine is a Bravo 4 place model, with an IO540, electric fuel pump, no return lines, and a fuel selector with L,R, BOTH, OFF.
I've attached a short video showing one part where I had the left tank selected before it was completely dry, and I was flying out of balance. After the engine surges several times, then stops, I selected the BOTH position and it restarts with the fuel pump off after about 5 seconds.
Incidentally the monitor sitting on the dashboard is a carbon monoxide monitor, which I've now installed permanently on the right wing root panel. It works much better than the card type, has an audio alarm, and a digital readout. It costs NZD$53, which is a cheap insurance in my books and I've learnt that the cards don't often register a low but continuous CO level. As a result I've also installed a small gurney flap ahead of the gascolator fuel drain which has cut the CO ingress a lot when running ROP. When LOP the levels are zero.
Here a link to the video showing testing of my fuel system, and my experience with carbon monoxide.
