Good evening everyone. I thought I would give a brief report on my recent visit to the kit factory. One main objective was to show the guys how to install the boot cowl sheet metal. We want builders to just pull out the sheet metal parts and have them 100% trimmed to fit and can be cleco'd together easily right after unpacking. The starting point was the have the instrument panel and firewall in place. Also the tunnel and former that the aft end of the tunnel attaches to. We did this on a Model B but really the same thing applies to all the different models.
The executive decision was made to tilt the top of the instrument panel forward 10% from vertical. If a builder wants more tilt - it is easy. To have less tilt is not so easy. The panel was tilted and some 3" .025 angles were drilled & riveted to the forward side of the panel top. We got the angle flanges adjusted with a long straight edge on these angles and the flange of the firewall. We left 3/8" of an inch of aluminum hanging over the instrument panel top because I like to put some hard rubber there as protection from impact. If someone doesn't want that - it can be trimmed off.
We got all the parts in place drilled with a few (but not all) the holes. They will make the cut outs around the door hinges and landing gear fittings as small as possible. This will all save builders a bit of work. The kits coming in late February will all have the boot cowl trimmed and drilled/ready to install as I have tried to describe.
They had made a pretty cool tool to shear the thousands of little steel tabs needed. Band sawing them as we used to do is quite time consuming with all the kits being made now and getting shipped. They also had a pretty clever way to form the aileron pocket skins. Around a round wood piece with a groove cut into it.
The new factory addition includes a "break room" for everyone to eat. In addition they have started installing strong extraction fans in the paint room, sandblast room, and the little room where they melt and pour the lead for the elevator counter weights.
Also attached here is a pic of the reinforcement Bob drew up for the tail section longerons. This is now going on all the kits.
I am quite proud of what those guys have achieved. Mark 20221209_095002.jpg20221209_112554.jpg20221208_162119.jpg20221207_092058.jpg20221207_150640.jpg20221207_115218.jpg20221209_121706.jpg
