Can someone school me on engine Lycoming Service Bullitens andAD's? I'm wondering how I would learn if my Bob Barrows IO-360-exp engine has any that apply.
Lycoming Service Bulletins and AD's
Here is the website.
Enter your engine make and model and it will limit them down. Then you need to just verify the serial is affected by the AD.Travis M
Kentucky
Bearhawk 5 Quickbuilt Kit Plane #5041
Received December 2022
It might be worth a call to Bob to see what he suggests and to see what level of effort he thinks make sense. The basic problem is that an experimental engine may not be a clear "make and model' from the manufacturer's point of view. I have one of Bob's engines. If you look in the log you will see that he has probably entered something like "built from parts to 0SMOH standard...". The serial number on my engine tells me that it was originally shipped to Mooney as an IO-360-AIA. It is certainly not that now. All I know for sure is that the case is from that engine. I imagine that the crankshaft and a lot of other internal parts are also from the same engine but I don't know for sure. I know that some of the parts are definitely not from that engine (it has a carburetor now, different magnetos, probably a new cam etc.). Short of having part level serial numbers and the ability to search ADs based on them, I'm not sure how far you can get.
I spoke to Bob about the recent Lycoming AD for conrods. He told me my engine doesn't have the Lycoming conrods.Nev Bailey
Originally posted by 500AGL View PostGreg is correct. Nothing you can look up will apply without conferring with Mike/Bob about exactly what was installed. Or whomever you purchased an experimental build from.
pb
Originally posted by jaredyates View PostDid Bob happen to give you a stack of yellow tags with the engine, or make any entries that might specify any serial numbers for internal parts? I make up a chart for each of the accessories with their serial numbers, part numbers, etc.
Originally posted by Nev View PostI spoke to Bob about the recent Lycoming AD for conrods. He told me my engine doesn't have the Lycoming conrods.Brooks Cone
Originally posted by Bcone1381 View PostCan someone school me on engine Lycoming Service Bullitens andAD's? I'm wondering how I would learn if my Bob Barrows IO-360-exp engine has any that apply.
It may already be obvious; every other part which is bolted on to the engine (usually made by a company other than Lycoming) can have AD(s) too - and they are all just as important as ADs on the engine core. Any of those ADs can address a serious safety issue.
Unfortunately, a prudent operator needs to check all those AD details every other year at least. It is a rather time-consuming job.Last edited by Battson; 12-19-2024, 05:28 PM.
I guess the other aspect of this question is - are you ONLY interested in the engine core?
Note that this was just a side discussion. I don't want to indicate that this was anything official.
In my situation, I purchased a Lycoming factory built YIO-360. Getting specific info on the engine based on the model assigned to the engine isn't straightforward. Still waiting on tech support to answer a list of questions I sent to them last week.
Tow things. 1) When I browsed the website in post #2, I used the engines I thought most closely aligned with my engine. O-360-a1a, and IO-360-b1b. I found a Crankshaft AD for a Superior crank, and a Connecting Rod AD. I thought I would see more than that.
2) There is a connecting rod AD. To understand if it applies to my engine I would need part number and dates that parts were shipped from Lycoming. I want that info, but have no access to it. I wonder how the FAA will view missing information.Brooks Cone
