N22GM IO360 EFII Dynon
  • Bearhawk 4-Place N22GM IO360 EFII Dynon
    First flight N22GM was a few weeks ago. Has a Bob IO360 with EFII fuel injection and electronic ignition. Dynon panel. Fight went pretty well, had some cooling issues that were solved by a bigger cowl exit and a spoiler. Needed a tiny bit of rudder trim. Fabric is Oratex, with vinyl trim.
    This gallery has 3 photos.
    Another beautiful Bearhawk!
    congratulations!
      Very nice! Well done!
        Wow, I would park it in the living room ! Stinger
        • Greg_Marlow
          Greg_Marlow commented
          Well, there's a couch, recliner and TV in my hangar, so does that count? ☺️
        Very nice Greg! I'm thinking about EFII too. Did you use a header tank?
        • Greg_Marlow
          Yes, a 6 gallon tank on the bulkhead wall.
        Beautiful.
          Very nice Greg. Your BH turned out beautiful. Congratulations. Mark
          • Greg_Marlow
            Thanks Mark. Couldn't have done it without your help.
          Spectacular ! Great job. Question: did you do your own seats? Do you have a pattern for the foam? I really like what you have there....
          Cheers
          Maule M5-235C C-GJFK
          RV-8 C-GURV (Sold)
          • Greg_Marlow
            The seat foam came from Oregon aero or the other major RV interior vendor, I cant remember which. Specifically, they are foam for the Rans S7S, which fit the Bearhawk frames pretty good. Then, a local auto upholstered took it from there.
          • rv8bldr
            rv8bldr commented
            Cool. That's good info. Thanks, Greg.
          Wow, very nice. I like the look of the polished aluminum skin with your paint color scheme.
          I'm curious to see what would be the speed gain with the wheel pants...
          Mike.
            Wow!!!
            takes your breath away....what a great looking machine...bravo sir....
            when you have a chance ...please do a walk around video with the trials and tribulations you went through..
              That is just beautiful. I love polished planes but that must have been quite a job polishing the bottom side.
              Scott Ahrens
              Bearhawk Patrol Plans Built
              #254
                Beautiful plane Greg congratulations!!!
                  Very sharp, inside and out. Did you do the vinyl trim yourself? Any issues with it?
                  Also, on the dash is switch marked "Emergency Power" - is that a secondary battery, auxiliary alternator, or?
                  Eric
                  Eric Peterson
                  4-Place QB
                  Camarillo, CA
                    No, a local vehicle graphics shop did the vinyl. Took 2 days.
                    The emergency power switch allows you to bypass the bus manager and delivers power directly to the EFII components to keep the motor running. I have two batteries, either or both can supply power to the busses.
                    Greg
                    • grog
                      grog commented
                      Thanks Greg; that EFII looks quite interesting - I'll have to look into it more.
                      Nev commented
                      Nice looking machine. Also very interested in the EFII - keen to know how it goes.
                    woooow great job. I really like the exterior design. Can you describe in detail your instrument panel? thanks and good flights !!!
