Here is a link:
Engineering Change from Bob Barrows
Due to one Bearhawk fuselage tail section being damaged in off-airport usage (gravel bar), we recommend the following:
When making sharp turns where the tailwheel is turned at 90 degrees to the tail spring, and the ground is rough, do your turn very slowly to reduce shock loading.
We have designed a reinforcement gusset to about double the strength of the tail section in this mode of overloading.
