I have finally started my build and I am loving it so far. It's a lot to take in at first but it's also very addiction to solve all the small mysteries and riddles.
I started with the tank cap and the main landing gear. It turned out I am missing all kinds of fluids. This is the list I came up with but would be interested what other builders are using.
MIL-H-5606ATF to fill shock struts and lube o-rings- MIL-H-5606 brake system (later)
- Loctite
243565 to seal threads- shock struts (don't like handling leaky parts)
- NPT threads in fuel system (with Loctite 7649 primer)
- Loctite 620 retaining compound (tailwheel rod/socket, in case of play)
- EZ Turn to lubricate tank cap threads
- Aeroshell-22 to pack Grove wheel bearings
- Aeroshell-22 to lube o-rings in tank cap and other general lubrication needs
I like yours too. It has been very helpful.
