I have pretty much completed my wings and am well into the fuselage. Tools required for the sheet metal were as expected. Now however, I find myself building lots of little brackets, clips, flanges, and mounts. I foresee a great deal more of this work ahead. I have a 4.5” grinder, wood bandsaw and a very small bench sander with a wheel and a 1” belt. The sander is pretty wimpy, but I can do the outside cutting and shaping with these.
For the inside shaping, I’ve been using step drills, files, and a dremel with little sanding wheels. It sucks! What do you folks recommend? Better dremel bits? If so, what kind works for aluminum? Or should I step up to a die grinder? In that is the case, knowing that the bits are critical, what should I get? Thanks.
