I had a chance to pilot a new B model Bearhawk recently, and noticed a difference between the seats and the view which I thought it worth sharing. There were two different ways of doing it - each with different benefits.
In our 4-place, we have a seat pan with soft foam and webbing straps, which allows the pilot to sink down into the seat a little way, perhaps 2 or 3 inches.
In the Bravo I flew (noting the different wing profile), they had thicker and firmer foam with a solid seat pan - aluminum I think. So the seating position was higher to start with, and there was very little sink into the foam. Overall, the seating position was at least 4" higher.
I noted some differences in the piloting experience.
- With the lower seating position, over the nose visibility was slightly reduced, but I could see under the wing and also put my head out the window to see what I am taxiing over in an off-airport situation.
- With the higher seating position, forward visibility was fractionally better (not a lot - tire size is the main factor), but I could not see the underside of the wing - when I looked left all I could see was wing root and fuel gauge about 6" in front of my face. I could not crane my neck low enough to get my head out the window. This changed the feel of the plane, making it a little more enclosed. My head was also very close to the structural tubing (skylight, no headliner) and the headset was touching the overhead cross-bars when we hit turbulence.
