Today as I am reading thru part of Eric Newtons Bearhawk Builder's Manual. (Specifically the Volume 1 Wing Manual, part 8, p.13) Eric Newton adds a grounding lug to the fuel tank to facilitate grounding the tank to the wing because he uses rubber as a cushion between the fuel tank straps and the tank.
This is the first I've thought of grounding the tank.Are others grounding the fuel tank? If so, by what method?
I am thinking maybe an AN472 aluminum loop clamp around the AL fuel line near the tank. Then a wire with a ring terminal on each end to ground the loop clamp to a rib. Is there a industry standard that demands it be attached directly to the tank?
