I have a question about squaring the nose bowl with the fire wall. I just finished building the plywood hub that is used for holding the nose bowl to the crank, when I clamp a straight edge on it to check squareness to the firewall the sides are perfectly even at 41 3/4†on both sides but the vertical plane is way off, 42 3/4 on top and 40 1/4 on bottom. Am I missing something?
Engine is an O-540 with type 1 mounts
