Hi Builders,
I am trying to figure out wheel kits that work well with the Goodyear 26ers on a Patrol. There are two considerations (1) brake disc/tire spacing and (2) tubeless. If anybody has part numbers for a working setup that would be most helpful. I am specifically interested in Grove 66.152 or
(1) From what I could gather you run into a spacing issue between the tire and the brake disc with tires bigger than 850. I found three forum entries that talk about that extensively but still could not come up with a specific part list.
https://bearhawkforums.com/forum/bea...els-and-brakes
https://bearhawkforums.com/forum/bea...tion-questions
https://backcountrypilot.org/forum/2...-caliper-17861
The solution seems to be either a spacer between the brake disc and wheel (possible also requiring longer wheel bolts) or a deeper brake disc (e.g: 164-03601 -> 2.597" deep instead of 164-01501 -> 2.355" deep). Latter solution, according to @rvanbladeren, does not work on a Bearhawk because you run out of axle length.
(2) The Goodyear tires can be used on a tubeless wheel. I would prefer that. Unfortunately I haven't found much about it being used. Grove has the
Looking at the 66-152 most of the measurements look pretty much the same. Also the anchor bolt/bushing engagement on the
