RE: Avidyne IFD-540
I also posted this problem on the Avidyne Forum. Not much traffic there, so I thought I would try this non-Bearhawk build question here since our community has always been very helpful. And I appreciate that very much!
____________
I am almost ready for the first flight of my Bearhawk Model B. I've been performing some taxi testing and calling for random radio checks occasionally. Those that can hear me are relatively close. Near the runway the AWOS antenna is about 2500' away and in my line of sight. I cannot hear the AWOS unless I have the squelch on. Friday we did a high speed taxi test down the runway. The plane behind me on the taxiway heard our call to take the runway. However when I turned off at about 4,000' he could not hear when we called clear of the runway.
A friend of mine called his avionics buddy. He suggested that I install a ground strap to one of the mounting bolts to my belly mounted Comant VHF CI-122 antenna. Effectively grounding the antenna to the airframe. He says they do that on all of their antenna installations. I did. You can see the #10 screw and washer just 4" to the right of the antenna base where I connected a 10ga copper wire. This did not change anything. I am still having trouble receiving and transmitting.
I am using RG400 coaxial cable and RG400 BNC fittings.
Today Amazon is delivering a SWR meter and I will test the signal at the antenna BNC connection.
Any thoughts on how I can improve my reception and transmissions? I REALLY do not want to move the antenna if I can help it. Other than GPS pucks, I do not care for top mounted whip antennas. If you've seen my head, you know my aversion to hair!
Thanks for any suggestions!
____________
