This is a bit of a random one.
If one were too remove one's feet from the rudder pedals for a short period of time, should the aircraft remain balanced, or is it normal for it to yaw away from balanced flight ? I've noticed that mine will yaw to the left at cruise speeds. It does this slowly, but progressively. I've added a small rudder trim tab which has removed the need for continuous right rudder - it's made a huge improvement actually and now it requires only small rudder inputs to "trim" for speed.
Part of the flight test proforma here requires a skid to be introduced and looks at the aircrafts ability to return to balanced flight. Any advice from those of you with flying Bearhawks (and experience in this area) is appreciated - obviously it's something I'd like to correct prior to flying with a lower fuel quantity as it would increase any risk of unporting.
I'm certainly getting much better at using my feet after relying on yaw dampers for many years, (so that's not where I'm going with the above question).
I should stress that I'm only part way through flight testing, with the aim of making any rigging changes needed to result in an aircraft that flies and handles very well and as it is designed to.
