When I was flying my initial time in the Patrol, I had one wing a bit heavy and needed more left pedal on the rudder. I corrected the heavy wing by adjusting a flap push rod one turn; can't remember which one and which way I moved it, but one turn and wings were level. Now the rudder was a bit different. My plane was a plans project and when I made the vertical stab, the offset was put in at the top and bottom forward tube so the whole fin was offset. I discovered I wasn't the first person to do this. I installed a stiff spring at the rear left rudder pedal to the flap handle assembly with a tab that had attach holes at different lengths so the tension could be strengthened or loosened. Hands off at 145 mph. When I install the amphibs I recently picked up, some of that will change for sure.
I basically didn't do anything for the first 30 hours but take off and concentrate 100% on engine break in. Before I went to work the past May, I was just starting to get into circuits and slow flight and as I found as those that have gone before me, slow the friken plane down!! I was quite happy with what was happening with my progress getting the aircraft on the pavement.
After working the summer on much larger aircraft and sitting 8+ feet off the water for 350 hrs, all that I had gained in the past spring went for a dump. I came home in October and went for a short flight. Needless to say, I was quite happy to see there were no witnesses to my return to the pavement.
The Patrol is the most sensitive aircraft I have ever flown, especially with pitch and rudder. You have to make a strong mental note to slow down and not move anything until your sure you need to. The DeHavilland aircraft I have flown required constant searching for pressure on both sides of control surface forces as this changes so much with reducing airspeed. So with the Patrol, I am over controlling the stick and rudder to the point that must be quite comical to observe from the ground! I know it's only a matter of a couple of hours of getting use to but man, aviation is so humbling!
