What are guys doing for aileron control stops ? Previously I was under the assumption that the control stick fixture provided a stop by limiting the travel of each stick. But on a recent 50 hour check we noted that the aileron linkage was able to contact the aileron hinge mount, so the control stick housing is not limiting movement on that side. I would prefer to have a softer material, maybe bush nylon or delrin. Any ideas appreciated.
Aileron Control Stops - 4B
Builders Log - We build planesTags: None
Hi Nev, The limits should be managed by the geometry of the system bellcranks etc. There isn’t a hard physical “stop” in the control stick assembly or elsewhere. In my case I had to carve a curve into my control stick assembly where the stick hit the edges of the fixture - to enable full movement. I guess If you are getting interference somewhere in the system you may need to do something similar. I found a pic indicating where my interference was. 65265290240__D0FE3FE9-56D0-4EC6-B4C3-97E7FD7F053D.jpgLast edited by AKKen07; 10-31-2023, 03:34 PM.Almost flying!
I remember this came up for a Canadian builder who had a regulatory person who required control stops for the ailerons.
This was a discussion from the LSA section but I was thinking there was another somewhere.
The MDRA representative required me to install aileron stops before he’d sign off for flight. I built Dutchman clamps that were attached to the bellcrank support tube to limit motion. A little fiddly to install but serves the purpose. Some thin wall rubber or heat shrink tubing on the stopper could be used to provide a cushion.You do not have permission to view this gallery.
Nice solution. Graham Johnson has made a very similar fitting with a plastic block attached. Both make for an elegant solution. I was thinking that one per side would provide the limiting I was after.
0784E622-99B2-40C6-A312-D04192B2BDCB.jpgNev Bailey
From that idea, springs another....for those who might avoid welding.
Below is pictured the MS27405 tubing clamps. Type A has one lobe. Type B has two lobes. A fitting would be added to the loop clamp to create the stop.
I've hit this point in my 4A QB project, and haven't solved this aileron stop puzzle yet. I'm not finding anyone selling the MS27405 "Type B" suggested by Bcone1381 . Got some "Type A" on order. My welding skills aren't to the point where I can pull off the "make from scratch" solutions shown by Nev and mbaerobat . Does anyone have any solutions to share, for someone who "might avoid welding"?
Dpearson Univair had them in the size I needed to make a rear shoulder harness attach point arount the fuselage tubing. I think I lucked out, because they don't make them in a variety of sizes as I found out during my search for them...clamps (MS27405-T5)
Try Genuine aircraft hardware. 888-247-2738. They have virtually no website and answer their phone without a menu. They know aircraft hardware. Have them send you there hardware book.Brooks Cone
Thanks for the tip! I called GAH and they answered right away. They didn't have MS27405-T6 (3/4" ID) in stock, but the representative was nice enough to do an exhaustive search and eventually found a few at Boeing/Aviall for > $100 per half clamp. Beyond my price range! I will see what I can cobble together.
