May I ask what mechanism/method you guys are using to measure your control surface deflection? I have some ideas for makeshift protractors but I’m curious what others are doing?
Elevator Travel
Back before I had a digital level, I used a school kids protractor to make a cardboard template. But it's a little complicated on surfaces that aren't flat, like the Model B tail or the wing. But the digital level is handy for lots of things, even ignition timing, and I think the one I got was around $30.Originally posted by AKKen07 View PostMay I ask what mechanism/method you guys are using to measure your control surface deflection? I have some ideas for makeshift protractors but I’m curious what others are doing?
I did what Jared did using weighted piece of safety wire (instead of a plumb bob) as my "pointer". I just placed the protractor in alignment with the upper surface of my favorite elevator rib. With the elevator clamped in a streamlined position to the horizontal stabilizer and the wire hanging over the protractor I called that my Zero reference point.Last edited by Bcone1381; 01-08-2021, 07:18 PM.Brooks Cone
Do you have a smartphone? They make these crazy things call apps and they even have some that are digital levels! Amazing! ðŸ˜
But in all seriousness, I bought a digital level from Home-depot and it was really handy. I compared it with an app on my iPhone and they were the same. The digital level gives me a warm fuzzy over my phone but I honestly don’t think the result it any different. Either way...protractors are so 1900.😄Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I bought a digital level, in part so I could also use it to set the prop pitch. I could have used the phone, but my phone is in a "rubbery" case, and it has some bumps on it that might affect the actual "level" and make repeatability challenging. Also, the digital level is just long enough that I can loop a rubber band over one end of the level, then over the front of the prop blade, and around the other end of the level, thus holding it in place so I can use both hands to set the blade pitch... I couldn't do that with the phone.Jim Parker
I used an app on my phone. Even with the case in its within 1/2 degree. Brilliant piece of kit.Nev Bailey
I think the compass on your phone would work for measuring rudder travel.Whee - how do you apply that to the rudder to measure it's travel?Nev Bailey
