One of the gotchas that might be easy to miss, is the 0 degree flap setting, the pushrod needs to be resting (pulled actually) up against the pad on the tubing. If it isn't, or one side isn't, you can adjust the flap pushrod to zero, but in flight, with air loads, it might go farther up, past zero. Result - heavy wing.
I didn't realize how much force the flap springs would impart to the mechanism. You cannot properly adjust the cables without all 4 springs attached - not 1 or 2, but all of them. Which makes adjusting them (and making them) much harder. There is a lot of torsional flex in the torque tube. I ended up pulling the cable off of the pulleys, and sometimes removing a pulley, rather than remove the springs to adjust something.
The springs are also a bit hard to install and remove. I used pieces of 100# fishing line to pull the spring aft onto the arm, pulling the line straight back through the hole in the aft spar.
I will try tonight to come up with the actual procedure used to do all of this.
