Yesterday, a kit builder made two suggestions about two "options" he would have liked to have seen when ordering a kit. I would like input from kit builders or just guys interested in the kits. We are talking 4 place BH here.
First, a decent percentage of builders install a skylight and usually have to modify some things to get it to work as Bob designed the upper cabin for fabric covering. My question is this: How many have used skylights or alternately wish their kit had been set up by the factory for a skylight? I understand the serious mountain flyers view the skylight as very beneficial. But not everyone flies in those mountain valleys.
The easiest way to do this would make all kits set up for a flat skylight piece that goes all the way across. And source some really dark plexi for builders who are in HOT areas like Texas where I am.
Seaplane doors - it would seem possible to design a one piece swing up door that would basically fit in with what we have always done. Either put a mouse door on the bottom so it clears the strut or alternately have a cut out on the lower door and a piece attached to the door sill that would seal the cut out when the door is closed. I expect not as many builders would want this as the upper window that opens on the ground and in flight is used often. The idea is to keep our normal doors/windows but make some seaplane doors that work with everything else and be optional.
Please let me know what you guys think. We appreciate the input and will help us decide what the best way is to go forward with these potential changes. Mark
