How are people installing fuel flow transducers in their Bearhawks ? (I’ve got a Gold Cube FT90 fuel flow transducer to install). My initial plan was to bolt it to a frame between bulkhead B and the firewall. This gives great maintenance access, tons of room, a solid mounting point and the required uphill flow after the transducer.
However the instructions state that it should be installed after the last fuel pump, and should be supported by flexible fuel lines - presumably to dampen vibration, but the unit does have enough weight to it that I would have been inclined to bolt it to something solid. A search around the web shows quite some variation on installation method and location. There’s also some that were supported between solid fuel lines that subsequently detached. Would appreciate advice if anyone has firsthand experience. Thanks.
