I bonded my forward cargo door skin to the frame last week, after much consideration. Doing the rear one first would have been preferable in my mind with the over-lap, but it didn’t work out that way and the rear door is done with countersunk stainless rivets which also gives a very nice finish.
Obviously the failure mode is of prime consideration and in the case of the forward door it would probably be rather rapid, but not catastrophic. I believe the likelihood of this to be low and the finished strength appears to be as strong or stronger than rivets. There’s significantly more surface area attached than with rivets, and little chance of skin cracking etc.
Inside the door I’ve added a bonded grab-latch to assist with opening. This should take as much stress as any of the bonding due to the latch spring strength, and I think will act as a “canary in the coal mine†as the adhesive ages.
For the bonding I’ve used Scotchweld DP190. It has a small flex to it rather that complete rigidity.
Most of my time was spent in researching how secure the installation would be, and how best to prepare the surfaces. Actually once I decided to proceed it was all relatively straightforward. All bonding surfaces were either kept bare or in the case of the door frame, a strip was taken back to bare steel, then scuffed, degreased and cleaned. The DP190 goes on easily, and is able to be handled after around 12 hours. I kept the parts at room temperature (dining room temperature in fact) for several days, full cure takes a week.
I welcome all feedback, concerns or otherwise. As always, if you see something that I don’t, please tell me. If I can find a way of attaching a video later I’ll do that too.
