Fuel Flow Discussion, Moved from Float Mounting
  • #76
    Bob has made some suggestions for flying your planes:
    OPERATION OF BEARHAWK FUEL SYSTEM
    Take off and land on Both at fuel valve selector.. Be sure
    both tanks have fuel in them.
    Cruise can be on left or right to insure both tanks have fuel in them.
    Both can be used if flow is about even.
    In rough air on landing stay high, do not drag it in if fuel is low.
    Bob has no problem with any of us adding a vent tube between the two tanks. With a gravity flow system, he does not think it needed. But no harm for sure except the following point. If you do add a cross vent tube, you will have fuel coming out of the gas caps if you park the plane on a slope. Without the cross vent, you can just turn the selector valve to off.
    Bob understands that having any fuel pump, especially the higher pressure pumps used with fuel injected engines - will suck air and not fuel if given the opportunity. He thinks the Continental fuel injection system might be a little worse in this regard than the Bendix system used on Lycomings.
    He feels with low fuel level in the tanks, slipping or skidding (or even rough air) while on approach to landing can cause an interruption of fuel flow. If you think about being in a bank and slipping or skidding so the fuel in the upper wing tank sloshes outboard could un port the fuel outlets. Mark
    • AKKen07
      AKKen07 commented
      Thanks for that!
    • zkelley2
      zkelley2 commented
      Just an fyi, not all fuel sector's "off" will prevent cross flow. For example on a maule you have to put the selector in r or L to prevent cross flow. Off just blocks the port going forward but is just as open to both tanks as the both position is.
  • #77
    Thanks Bob/Mark,
    • #78
      I am considering install of the crossover vent from top of sight glass connections, with a small Parker shut off valve for parking unlevel. Crossover may not be needed, but shouldn't hurt anything either. I'll add it to check list. I do return more fuel to the right tank maybe a crossover will help with that.
      • Archer39J
        Archer39J commented
        Then you have to think about how to purge fuel that gets into the low spots or you'll not be equalizing the pressure between tanks.
      • yateselden
        yateselden commented
        AKKen07 definitely better tapping into outboard tank ends if your still assembling the wings. I would need to remove the tanks, work in the closed up wing. But I don't like the idea of connecting the sight gages or having a valve either. Welding in bungs in tanks that have had fuel in them doesn't excite me at all. All things considered I think I'll let it be.
      • AKKen07
        AKKen07 commented
        Thanks, I haven’t uncrated the wings yet, so lots of time to make whatever changes seem prudent.
    • #79
      Here is a collection of fuel tank diagrams of certified aircraft I found on-line that I thought may help visualize this discussion.
      Below is (with a 95% confidence feeling) a C-152. Lycoming O-235 engine. The C-152 merely has a shutoff valve, so its always on BOTH. One vented cap + a cross vent + a tank vent with a check valve.
      Below is a Cessna 174N with one vented cap. The C-172 N has a carbureted Lycoming O-320 engine.
      I note two things here, the cross vented tanks and the vent line between the fuel supply line and the cross vent. I see this on all the later model Cessna's, C-172's, 180's, 182's, If parked on a left leaning slope, some fuel will drain from the right tank. If the vent line was run back to the right outboard of the right tank it would not drain out. What happens if the check valve fails closed? The R tank's vented filler cap should relieve a pressure differential.
      Cessna 172S. This is the latest model of C-172 that has a Lycoming IO-360 engine instead of a carburated O-320. Cessna designed the system with a header tank (fuel reservoir tank). Note how the header tank is vented. I don't see vented fuel caps on this application. What happens if the Left tanks vent's check valve fails closed? I think negative pressure would build up and the engine would fail with fuel in the tanks. I question if the schematic is accurate by showing the unvented fuel caps.
      Cessna 177 Cardinal with header tank. Cardinals were made with both carberated and injected Lycoming 360 CI engines. I'm not sure which one this set up was designed for. No check valve. No vented caps. Will fuel drain onto the ground if parked on a slope? I don't think so.
      Cessna 182S with a 230 hp Fuel Injected Lycoming IO-540 engine. Note fuel venting is all over the place. It has two vented fuel caps, a cross over vent, fuel supply lines vented, and a vent in each tank. This fuel system does NOT have a header tank.
      What conclusions should we draw?
      • #80
        Originally posted by Battson
        So I think the conclusion is, if you have fuel injection - you NEED to install these vents to be on the safe side, or avoid unbalanced flight if you have a low fuel tank.
        I wish I knew this before the plane was assembled! Going to be a difficult mod to get right without easy access.
        That said, I slip all the time with low fuel, I have no cross vent and never had a problem with the Bendix system... because I never had a blocked vent. If the vent blocks, then I run the risk.
        "To be on the safe side" is a great way to add unnecessary weight to an airplane.
        ​​​​​​Fuel injection doesn't inherently necessitate a cross vent. If you're worried about differential pressures there are simpler ways around that.
        Dave B.
        Plane Grips Co.
        www.planegrips.com
        • #81
          You mean like carrying two complete independent ignition systems, stabilizer struts as well as flying wires, tires larger than really necessary, a backup battery for electric ignition?
          Sometimes you need an backup plan.
          Clearly this is a real risk, we have two firsthand accounts right here. So anyone with fuel injection should be worried about differential pressures - especially high pressure systems.
          If a mason bee lodging itself in a tank vent can bring the whole plane down, then I'll be installing a backup system.
          What are the "simpler ways around that" - I am keen to hear what other options I have, which are simpler than a bit of tube between tanks.
          The designer who made one of those decisions also said a cross vent isn't necessary. The risk is there fuel injection or not. But I'm sticking with gravity feed to the pumps so my solution would only be applicable to a otherwise gravity fed system, if you're sucking at the pump good luck and I don't see a cross vent affecting that anyway off the top of my head.
          My solution is a check valve on each tank, ones that open at a pressure well below the pressure head of the fuel. Air gets in if your cap vents get clogged, doesn't let fuel out, doesn't remove your ability to isolate tanks on a slope, and won't let fuel settle in a low point for those wanting to go outboard side to outboard side with their cross vent (dihedral isn't shown in any of those fuel diagrams).
          Not 100% on this solution but it's where I'm leaning.
          Dave B.
          Plane Grips Co.
          www.planegrips.com
            I understand you are not a 'gravity feed' fuel system if you need pumps to keep the engine running. You are pumped. In that case, you run the risk of losing all fuel supply to the engine, if one vent is blocked.
          • Archer39J
            Archer39J commented
            Sure the engine isn't gravity fed but the pumps are, verses pumps that are sucking fuel. The pressure differential in the tanks isn't more than the pressure head at the fuel selector. There's no difference between a gravity fed pump and a gravity fed engine at that point, and one clogged vent shuts off that tank after a while. I don't know what would happen with a pump that is sucking fuel, but I think it could only be worse.
        • #82
          There is still confusion on this topic but I don’t know how to resolve it.
          The issue has nothing to do with a pump sucking air. It affects both gravity feed carburetor systems and fuel injection systems. Matt’s failure was with Continental Fuel injection. The two times I experienced the failure it was in a Lycoming O360 powered plane. Bendix fuel injection might actually be more tolerant of this issue because of the types of pumps used.
          The issue is having the higher air pressure in the airspace of one tanks vs the other. IDK how you equalize the pressure in the airspace of each tank without connecting them.
          Putting a check valve in the cross vent line, like pretty much all certified high wing planes do, easily solves the parking on a slope fuel transfer issue. Worth nothing that most fuel valves connect the tanks together when in the off position so you need to put the valve in either right or left when parked on a slope to prevent fuel transfer even if you don’t have a cross vent. Or verify that you valve maintains tank isolation when in the off position. My SPRL valve connects the tanks when placed in the off position.
          • Archer39J
            Archer39J commented
            Correct, I only mention sucking pumps because I haven't looked into that at all, since it's not what I'm running. You can equalize the pressures by having them vent to the same open space.
        • #83
          The check valve idea is interesting, and I am especially tempted because the cross vent would need a check valve anyway.
          However, I am not sure whether I would trust a check valve in my main fuel line - seems to introduce another potential engine-stopping failure point.
          In the vent line, a failure of the check valve is less risky.
          • #84
            I understand your machine had some other kind of vented cap, where the vent is not pressurised by ram air. It was unwritten, but I have assumed that unpressurised fuel cap must have played some part of the cause of the issues with your last plane. Set me straight if you see fit.
            I think we've established that with a gravity system conforming with Bob Barrow's design and with his design of fuel cap, the risk is negligible. As ever, it appears Bob is exactly right, let's be clear on that. We have no evidence of failure in a system entirely as Bob intended it. Bearhawk Aircraft has always been very clear that we diverge from Bob's approved design at our own risk. So here we are.
            With a conventional design, gravity feed system, it appears the chances of a failure seem almost impossible when you run the numbers. The engine needs so little fuel pressure to run and one of the tanks is always under some pressure, which reduces the risk further.
            In post #81, I drew the conclusion that fuel injection means you need to install this vent. I think that was jumping two steps ahead when I meant to just take one. I think all we can say for certain is, some fuel injection systems are at-risk of this failure, the high pressure ones. We actually have no evidence to suggest Bendix systems are at risk.
            Similarly, I didn't say that ONLY fuel injection systems are at risk. There are a million ways to design a dangerous fuel system, and only a small number of ways to make an inherently safe system.
            • #85
              Yeah I was thinking a check valve in a separate vent line that terminates inside the wing with a weep hole just in case, I described it in a comment a bit ago. That would solve the clogged cap issue but the commercially available ones I've found have opening pressures slightly too high for a reversed vent case so I'm considering making my own.
              Here's the one I was looking at https://www.mcmaster.com/5492k51
              ETA: I think the risk for my system is low enough for the reverse vent case though, fleet history being what it is in addition to my analysis. My main concern is icing since two clogged vents will take you out of the sky.
              Dave B.
              Plane Grips Co.
              www.planegrips.com
              • #86
                The caps were ram air pressurized. Same function as the Bob caps just a different form. The fuel system was built exactly as Bob specified except Bob caps were not available so a conventional cap was used. See pic of the conventional cap style cap.
                • alaskabearhawk
                  alaskabearhawk commented
                  FWIW,
                  Spoke with a mechanic friend about these caps. I see them often on Super Cubs. He said the STC for 180hp conversions require the pressure vent caps to meet fuel flow requirements.
              • #87
                Picture seems to have failed?
                Did they also have the o-ring seal to ensure the tank could develop positive pressure? As the air rushing over the tank could theoretically develop suction, if the vent blocked.
                This is all getting quite theoretical and esoteric, it makes it hard to discuss!
                • #88
                  I think I fixed the pic.
                  Theses "snorkel" style caps use either a cork or rubber gasket and their function is indeed to provide positive pressure inside the tanks.
                  I'd offer to induce the failure in my own airplane and video record it but since I have Continental fuel injection it would be of little value to anyone and the failure would probable get attributed an incompatibility with my FI. This summer I'll be testing an LSA. If I get feeling brave maybe I'll induce the failure in it and record it. But it is scratch built...
                  • #89
                    Cessna fuel systems are pretty Googleable. It is amazing how they evolved over the years. They didn't get simpler. I guess over the years the fleet got so many hours they kept finding a new corner of the envelope where the system didn't quite work.
                    I think I do want some additional venting. Right now I think I will just go with the cross vent in the middle, maybe with a shutoff valve. Mostly because it is easy to implement. I am not sure it is the best. I really like the Cessna 182S venting, but at this point it looks too hard to do. Maybe next time.
                    • #90
                      Battson, what is not theoretical and esoteric to me is your fuel system in your aircraft has proven itself to be dependable. You fly in BOTH and you know what a normal fuel balance is. In the future if you see an abnormal fuel imbalance, then a fuel venting problem may caused the imbalance. Be suspicious of the fullest tank. Switching from BOTH to the LOW tank might be prudent.
