March 2019 Elevator Trim Cable Tension
ENGINEERING CHANGE NOTICE: Design change that requires immediate attention to affected serial numbers. This NOTICE contains the technical information to correct the unsafe condition.
Applies to all three types, Bearhawk 4-Place, Bearhawk Patrol, and Bearhawk LSA.
Check the tension in the 1/16 cable used for the trim system. Cable tension should be approximately 60 pounds. If too loose the airplane will be unstable in pitch trim.
