Did a fuel flow test yesterday. Knowledgeable engine people tell me my modified parallel valve IO-540 should make 290-310 HP so I did my flow calculations based on 300 HP. Using the 1.25 factor for pumped systems I required a flow rate of 34gal/hr. Next decision was what climb angle to use. Others have talked about a max climb angle of 17-18 deg. I added the required 5 deg to that and set the test angle at 22 deg. In my case this required setting the tailwheel 34" lower than the main gear. To perform the test, I disconnected the fuel line at the inlet to the engine driven pump and drained fuel at that point. 3 gallons of fuel above unusable were placed in each tank. With the plane at that attitude the pump inlet was only 4 1/2" below the fuel level in the tank. Tested the left tank first and only got 12gal/hr!. Tested from both and only increased to 13gal/hr. Decided to redo the test at 18 deg, raising the tail to 19" below the mains. This only improved things slightly. 14 gal/hr left and right, 15 gal/hr both, not even half the required rate. I suspected that the Andair fuel pump might be part of the problem. I didn't wan't to tie up my 3 friends who helped position the plane any longer, a couple had traveled quite a ways to help, so we towed my plane back to my hangar. Last night I decided to test some more at the 3 point position of 13 deg. Only got 18 gal/hr each tank 19 both. Decided to test the Andair fuel pump, 46gal/hr with the pump running. Fabbed up a 3/8" line to bypass the fuel pump. That got 24 gal/h, a big improvement but still way below the 34gal/hr required. I'm really perplexed as to what the problem is. My system uses all 3/8" lines, from the Andair fuel selector it goes through the Andair gascolater, then the electric fuel pump. At the firewall is a straight stainless bulkhead fitting. From there a 24" 3/8th firesleeved teflon hose to the pump inlet. Prior to the flow test I had put 7 gal of fuel in each main tank and flushed through a drain just upstream of the electric pump. Pulled the gascolater filter and there were just a few very fine particles in it. I became concerned that my somewhat convoluted vent system might be the problem. I tested with the fuel caps off and there was no difference at all, so the vents are good. I've emailed Andair about the pump, seems like there is too much loss through it. Would love to hear the experience of others, especially someone that's using an Andair pump.
) etc.
